Camera Stops Working
I am having an issue with my camera going into a “x.x.x.x rejected our connection”
However, I am on the latest firmware and have had this issue for the last 4-5 versions. A reboot clears it but it comes right back.
I’ve submitted it to creality twice, never heard back at all. In the event anyone from creality comes across, I’d be happy to pull logs / wireshark / whatever you need.
I’ve found some other posts on here that the latest firmware resolved it, which is great, but has not for me.
It’s not a hardware issue that I can tell, as it consistantly comes back post reboot, then stops working after 10-30 minutes.
No retransmits or network drops on my side, it is pretty clearly a bug.
Duplicate of my issue: K1 Camera Not Connecting - #3 by Chris1
Bump for visibility
Hello @gorgarp and Welcome to the Creality Forum…! :wave:Creality
Sorry no one has been able to figure out this issue…
Have you tried to connect with the Ethernet port instead of wireless just to check it out…? I think the K1 and K1 Max both have ethernet ports…
Hello. I just tested it. No luck.
It is also worth nothing, I ran wireshark and am not seeing any dropped packets or retransmits. (You can see in the image above)
If there is any documentation on the handshake being used to connect to the camera, I can likely capture that to ensure it’s occurring correctly.
Does anyone know how to get a bug report in front of them? I’ve tried submitting via two methods but haven’t heard anything back (months ago on one, the other about a week)
TBH one would think a code defect on their “flagship” would be a bit higher priority, especially on the primary “value differentiator” between the K1 & K1 Max but yeah, not so much.
I’m also having this issue with the camera not responding after I start a print. I just upgraded firmware a few days ago, and that’s when the issue started. I even had the printer crash and reboot in the middle of a print today. Printer is only a couple of weeks old, and it’s been solid until the firmware update. The camera issue occurs on both the desktop and mobile app. I’m directly connected to ethernet on my network. Only way to restore the camera is to reboot the printer.
That is the exact same behavior I’m seeing.
Bump for visibility
I have confirmed it is pretty much a firmware issue. I’ve rooted, installed mainsail, and used orca slicer to do a print, the camera freezes.
As I thought:
Apr 5 15:13:54 K1Max-441F user.info kernel: [176717.386461] cdc_acm 1-1.1:1.0: ttyACM1: USB ACM device
Apr 5 15:13:55 K1Max-441F user.info kernel: [176717.813035] usb 1-1.1: USB disconnect, device number 26
Apr 5 15:13:55 K1Max-441F user.info kernel: [176718.028611] usb 1-1.1: new full-speed USB device number 27 using dwc2
Apr 5 15:13:55 K1Max-441F user.info kernel: [176718.130398] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=5
5d3
Apr 5 15:13:55 K1Max-441F user.info kernel: [176718.137762] usb 1-1.1: New USB device strings: Mfr=0, Product=2, Serial
Number=3
Apr 5 15:13:55 K1Max-441F user.info kernel: [176718.145734] usb 1-1.1: Product: USB Single Serial
Apr 5 15:13:55 K1Max-441F user.info kernel: [176718.151150] usb 1-1.1: SerialNumber: 5687023001
Apr 5 15:13:55 K1Max-441F user.info kernel: [176718.157381] cdc_acm 1-1.1:1.0: ttyACM1: USB ACM device
Apr 5 15:13:56 K1Max-441F user.err kernel: [176719.503620] usb 1-1: clear tt 1 (91b2) error -145
Apr 5 15:13:57 K1Max-441F user.err kernel: [176720.507712] usb 1-1: clear tt 1 (91b2) error -145
Apr 5 15:13:58 K1Max-441F user.err kernel: [176721.511633] usb 1-1: clear tt 1 (91b2) error -145
Apr 5 15:13:59 K1Max-441F user.err kernel: [176722.515659] usb 1-1: clear tt 1 (91b2) error -145
Apr 5 15:14:00 K1Max-441F user.err kernel: [176723.519670] usb 1-1: clear tt 1 (91b2) error -145
Apr 5 15:14:01 K1Max-441F user.err kernel: [176724.523698] usb 1-1: clear tt 1 (91b2) error -145
Apr 5 15:14:02 K1Max-441F user.err kernel: [176725.527702] usb 1-1: clear tt 1 (91b2) error -145
Apr 5 15:14:03 K1Max-441F user.err kernel: [176726.531739] usb 1-1: clear tt 1 (91b2) error -145
Apr 5 15:14:04 K1Max-441F user.err kernel: [176727.535763] usb 1-1: clear tt 1 (91b2) error -145
Apr 5 15:14:05 K1Max-441F user.info kernel: [176727.699210] helix-venc 13200000.helix: h264 stop streaming !
Apr 5 15:14:05 K1Max-441F user.info kernel: [176727.705260] helix-venc 13200000.helix: [2] encoder release
Apr 5 15:14:05 K1Max-441F user.info kernel: [176727.711432] helix-venc 13200000.helix: h264 stop streaming !
Apr 5 15:14:05 K1Max-441F user.info kernel: [176727.717478] helix-venc 13200000.helix: [3] encoder release
Apr 5 15:14:05 K1Max-441F user.info kernel: [176727.723480] helix-venc 13200000.helix: jpgd stop streaming !
Apr 5 15:14:05 K1Max-441F user.info kernel: [176727.729574] helix-venc 13200000.helix: [1] encoder release
Apr 5 15:14:05 K1Max-441F user.info MJPG-streamer [1113]: leaving input thread, calling cleanup function now
Apr 5 15:14:18 K1Max-441F user.err kernel: [176741.527983] usb 1-1.3: Failed to suspend device, error -145
Usb keeps connecting and disconnecting until it can’t connect anymore (likely a kernel safeguard)
Apr 5 18:17:49 K1Max-441F user.info kernel: [ 699.954323] usb 1-1.1: Product: USB Single Serial
Apr 5 18:17:49 K1Max-441F user.info kernel: [ 699.963742] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:17:49 K1Max-441F user.info kernel: [ 699.973336] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:17:51 K1Max-441F user.info kernel: [ 701.881747] usb 1-1.1: USB disconnect, device number 9
Apr 5 18:17:52 K1Max-441F user.info kernel: [ 702.090303] usb 1-1.1: new full-speed USB device number 10 using dwc2
Apr 5 18:17:52 K1Max-441F user.info kernel: [ 702.187254] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:17:52 K1Max-441F user.info kernel: [ 702.205190] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:17:52 K1Max-441F user.info kernel: [ 702.218442] usb 1-1.1: Product: USB Single Serial
Apr 5 18:17:52 K1Max-441F user.info kernel: [ 702.230871] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:17:52 K1Max-441F user.info kernel: [ 702.236876] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:17:54 K1Max-441F user.info kernel: [ 704.698136] usb 1-1.1: USB disconnect, device number 10
Apr 5 18:17:54 K1Max-441F user.info kernel: [ 704.906393] usb 1-1.1: new full-speed USB device number 11 using dwc2
Apr 5 18:17:55 K1Max-441F user.err kernel: [ 705.435831] usb 1-1.1: device not accepting address 11, error -71
Apr 5 18:17:55 K1Max-441F user.info kernel: [ 705.694546] usb 1-1.1: new full-speed USB device number 13 using dwc2
Apr 5 18:17:55 K1Max-441F user.info kernel: [ 705.792614] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:17:55 K1Max-441F user.info kernel: [ 705.801285] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:17:55 K1Max-441F user.info kernel: [ 705.809449] usb 1-1.1: Product: USB Single Serial
Apr 5 18:17:55 K1Max-441F user.info kernel: [ 705.815550] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:17:55 K1Max-441F user.info kernel: [ 705.821599] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:17:55 K1Max-441F user.info kernel: [ 705.978563] usb 1-1.1: USB disconnect, device number 13
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.191067] usb 1-1.1: new full-speed USB device number 14 using dwc2
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.295992] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.303405] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.315837] usb 1-1.1: Product: USB Single Serial
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.321048] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.331807] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.489760] usb 1-1.1: USB disconnect, device number 14
Apr 5 18:17:56 K1Max-441F user.err kernel: [ 706.491612] cdc_acm 1-1.1:1.0: acm_ctrl_irq - usb_submit_urb failed: -19
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.730376] usb 1-1.1: new full-speed USB device number 15 using dwc2
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.828001] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.843536] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.859078] usb 1-1.1: Product: USB Single Serial
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 706.864741] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:17:56 K1Max-441F user.err kernel: [ 706.872852] usb 1-1.1: can’t set config #1, error -71
Apr 5 18:17:56 K1Max-441F user.info kernel: [ 707.001612] usb 1-1.1: USB disconnect, device number 15
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.210403] usb 1-1.1: new full-speed USB device number 16 using dwc2
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.305085] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.320866] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.329302] usb 1-1.1: Product: USB Single Serial
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.335939] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.341833] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.513650] usb 1-1.1: USB disconnect, device number 16
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.722555] usb 1-1.1: new full-speed USB device number 17 using dwc2
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.819870] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.829615] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.845934] usb 1-1.1: Product: USB Single Serial
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.851341] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:17:57 K1Max-441F user.info kernel: [ 707.858095] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:17:58 K1Max-441F user.info kernel: [ 708.281752] usb 1-1.1: USB disconnect, device number 17
Apr 5 18:17:58 K1Max-441F user.info kernel: [ 708.498408] usb 1-1.1: new full-speed USB device number 18 using dwc2
Apr 5 18:17:58 K1Max-441F user.info kernel: [ 708.604253] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:17:58 K1Max-441F user.info kernel: [ 708.618151] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:17:58 K1Max-441F user.info kernel: [ 708.628521] usb 1-1.1: Product: USB Single Serial
Apr 5 18:17:58 K1Max-441F user.info kernel: [ 708.633651] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:17:58 K1Max-441F user.info kernel: [ 708.643960] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:18:01 K1Max-441F user.info kernel: [ 711.865754] usb 1-1.1: USB disconnect, device number 18
Apr 5 18:18:01 K1Max-441F user.err kernel: [ 711.871734] cdc_acm 1-1.1:1.0: acm_ctrl_irq - usb_submit_urb failed: -19
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.082452] usb 1-1.1: new full-speed USB device number 19 using dwc2
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.180751] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.188500] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.198523] usb 1-1.1: Product: USB Single Serial
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.204199] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.214998] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:18:02 K1Max-441F user.err kernel: [ 712.278323] cdc_acm 1-1.1:1.0: failed to set dtr/rts
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.377755] usb 1-1.1: USB disconnect, device number 19
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.586476] usb 1-1.1: new full-speed USB device number 20 using dwc2
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.680113] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.687540] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.695508] usb 1-1.1: Product: USB Single Serial
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.701486] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:18:02 K1Max-441F user.info kernel: [ 712.708027] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:18:03 K1Max-441F user.info kernel: [ 713.402133] usb 1-1.1: USB disconnect, device number 20
Apr 5 18:18:03 K1Max-441F user.info kernel: [ 713.638482] usb 1-1.1: new full-speed USB device number 21 using dwc2
Apr 5 18:18:03 K1Max-441F user.info kernel: [ 713.736363] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:18:03 K1Max-441F user.info kernel: [ 713.744137] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:18:03 K1Max-441F user.info kernel: [ 713.751764] usb 1-1.1: Product: USB Single Serial
Apr 5 18:18:03 K1Max-441F user.info kernel: [ 713.757373] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:18:03 K1Max-441F user.info kernel: [ 713.762840] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:18:04 K1Max-441F user.info kernel: [ 714.169736] usb 1-1.1: USB disconnect, device number 21
Apr 5 18:18:04 K1Max-441F user.err kernel: [ 714.175231] cdc_acm 1-1.1:1.0: acm_ctrl_irq - usb_submit_urb failed: -19
Apr 5 18:18:04 K1Max-441F user.info kernel: [ 714.386492] usb 1-1.1: new full-speed USB device number 22 using dwc2
Apr 5 18:18:04 K1Max-441F user.info kernel: [ 714.482239] usb 1-1.1: New USB device found, idVendor=1a86, idProduct=55d3
Apr 5 18:18:04 K1Max-441F user.info kernel: [ 714.492726] usb 1-1.1: New USB device strings: Mfr=0, Product=2, SerialNumber=3
Apr 5 18:18:04 K1Max-441F user.info kernel: [ 714.501021] usb 1-1.1: Product: USB Single Serial
Apr 5 18:18:04 K1Max-441F user.info kernel: [ 714.506257] usb 1-1.1: SerialNumber: 5687023001
Apr 5 18:18:04 K1Max-441F user.info kernel: [ 714.525213] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Apr 5 18:18:05 K1Max-441F user.err kernel: [ 715.586828] usb 1-1: clear tt 1 (0160) error -145
Apr 5 18:18:06 K1Max-441F user.err kernel: [ 716.590554] usb 1-1: clear tt 1 (9163) error -145
Apr 5 18:18:07 K1Max-441F user.err kernel: [ 717.595073] usb 1-1: clear tt 1 (9162) error -145
Apr 5 18:18:08 K1Max-441F user.err kernel: [ 718.598594] usb 1-1: clear tt 1 (0160) error -145
Apr 5 18:18:09 K1Max-441F user.err kernel: [ 719.586601] cdc_acm 1-1.1:1.0: failed to set dtr/rts
Apr 5 18:18:09 K1Max-441F user.err kernel: [ 719.602718] usb 1-1: clear tt 1 (9162) error -145
Apr 5 18:18:10 K1Max-441F user.err kernel: [ 720.606627] usb 1-1: clear tt 1 (0160) error -145
Apr 5 18:18:11 K1Max-441F user.err kernel: [ 721.610649] usb 1-1: clear tt 1 (9162) error -145
Apr 5 18:18:12 K1Max-441F user.err kernel: [ 722.614652] usb 1-1: clear tt 1 (1162) error -145
Apr 5 18:18:13 K1Max-441F user.err kernel: [ 723.618660] usb 1-1: clear tt 1 (9162) error -145
Apr 5 18:18:14 K1Max-441F user.err kernel: [ 724.622703] usb 1-1: clear tt 1 (1162) error -145
Apr 5 18:18:15 K1Max-441F user.info MJPG-streamer [1088]: leaving input thread, calling cleanup function now
Apr 5 18:18:15 K1Max-441F user.err kernel: [ 725.626717] usb 1-1: clear tt 1 (9162) error -145
Apr 5 18:18:15 K1Max-441F user.info kernel: [ 725.651581] helix-venc 13200000.helix: h264 stop streaming !
Apr 5 18:18:15 K1Max-441F user.info kernel: [ 725.659631] helix-venc 13200000.helix: [2] encoder release
Apr 5 18:18:15 K1Max-441F user.info kernel: [ 725.665972] helix-venc 13200000.helix: h264 stop streaming !
Apr 5 18:18:15 K1Max-441F user.info kernel: [ 725.672256] helix-venc 13200000.helix: [3] encoder release
Apr 5 18:18:15 K1Max-441F user.info kernel: [ 725.678308] helix-venc 13200000.helix: jpgd stop streaming !
Apr 5 18:18:15 K1Max-441F user.info kernel: [ 725.684671] helix-venc 13200000.helix: [1] encoder release
Apr 5 18:18:16 K1Max-441F user.err kernel: [ 726.630734] usb 1-1: clear tt 1 (1162) error -145
Apr 5 18:18:17 K1Max-441F user.err kernel: [ 727.634759] usb 1-1: clear tt 1 (9162) error -145
Repeatable with ease.
Still nothing here, via the bug report, or via the CS email. Cool.
Giving up. Obvious that creality doesn’t care, which comes as no surprise to anyone who has used any of their support mechanisms.
Same issue with my K1 Max, it’s been reported to creality support and nothing has come of it. I think they are clueless. So disappointed in this paper weight, will never buy another creality product again.
A firmware update came out today for the K1 Max and it might address the camera connection issue… Not sure… I haven’t updated yet until i’m sure it’s stable…!
Sadly, 1.3.3.8 did not help.
I did hear back from creality, who seemed to think these were related to temperature and printing with “hot” materials (aka ASA or similar).
Nope. PLA. Chamber sitting at a cool 34C.
After I responded with that, and the logs of the issue, radio silence once again.
