Just bought a second Falcon, this time a 40watt. My first Falcon is a 22watt. Do I need to set up a separate profile in Lightburn for the new laser or simply adjust the power and speed accordingly when I switch from one to the other? Thoughts?
Practically the 22W profile will work with the 40W as well. If you want perfect settings (the laser spot size in the 40W mode is not the same as in 22W mode) you can also use the separate profile.
