20 Minutes to Print from sending…
Continuing the discussion from SPARKX i7 Pioneer: Phase II Is Live!:
Not real impressed with this forum … wanted to start a new topic on the forum, but it was not very easy to observe..!!
That being said - Heading …. 20 Minutes to Print from sending…!!!
Just setup the SparkX i7 and did a number of prints and the quality was pretty good single and multi-color. HOWEVER there are a number of major concerns:
Before PRINT
  1. Does 3 Filament purges (even if previous color was the same)
  2. Bed Leveling 9x9 (81 probes) and does it at least TWICE before an attempt to print!!!
  3. Bed moving Fwd/REV while purging AGAIN (x3)
  4. Then FINALLY it will start to print (20 MINUTES AFTER SEND TO PRINTER)
This isn’t even laughable it is ridiculous and needs to be addressed.
If there is some way for me to control these settings — please let me know or I will have to return this printer as UNUSABLE!!
Thank You
Turn off the calibration before each print. that will take 15 - 18 minutes from print start.
Hi friend, before each print starts check to see calibration is turned off. you usually only need to run recalibration tests and bed leveling once id say every 6 - 7 prints.
My Spark takes at least 10 mins to start….no calibration checked. I agree it flushed way to much.
