3D scan from inside a tube
Dear creality-community,
I am trying to scan the inner wall of a tube with the otter scanner and crealityscan 4.3.1. The tube has an inner diameter of half a meter, some texture features on the wall to which I added some stripes of tape. But the result of a 360° full-turn scan given by the scan software is just an approximate 45° section of a tube wall. Whatever scan mode I try this 45° section always has the same size and clearly defined straight edges as if the software limits scans of concave objects to this angle.
What am I doing wrong ? - How can I scan the whole 360° resulting in a closed tube ?
Thank you so much !
Which scanner and scan mode are you using?
It is the Otter scanner - means IR mode and standard object /medium obeject size / high quality.
Meanwhile I managed to scan a full 360 ° turn with setting “small object” in another tube with extremely feature-rich texture (1…5 cm high “montains and valleys”) - which means the software is capable of doing it. But if the texture is less dominant the recognition mechanism easily starts slipping …. somehow I got several times these 45° portion … Is there somebody who has got experience in scanning “from inside” smaller objects and can give some recommendations ?
Is it possible to use marker stickers? Or other stickers and then using texture mode?
I guess it’s simply not able to keep the tracking going.
