I’ve just started using CP 5.0 and while I’ve familiarized myself with the most used settings, I can’t find retraction anywhere and it’s the one I need to tweak now. Searching “retraction” does not yeild any results in the UI. Thanks.
I found it under “Printer” in the upper left box. I wasn’t expecting it there. I was expecting it in the setting panel on the right side. Let me know if I’m using the wrong setting?
Thanks. I preferred the V4 where you could set it for each individual print if needed.
