A Reusable Checklist for Recording 3D Print Failure Clips (So Others Can Actually Diagnose Them)
A lot of failure threads on this forum include a video, but the footage often skips the parts that matter for diagnosis. A shaky ten-second clip of the extruder mid-print rarely shows what caused the issue. If you’re trying to get real help, the way you record matters almost as much as the print itself.
Here’s a checklist worth following before you hit upload:
1. Capture the first layer separately. Most adhesion and leveling problems show up here. Record it from a fixed angle, close enough to see the nozzle-to-bed gap, and let it run uninterrupted for at least the first few passes.
2. Get a clear shot of the nozzle and build plate together. A single frame that shows both, rather than cutting between them, makes it easier for someone to judge z-offset, squish, or clearance issues at a glance.
3. Keep the audio. Grinding, clicking, or a stepper skipping steps often tells more than the visual. Don’t mute the clip or replace it with music.
4. Show slicer settings as a separate screenshot or clip, not narrated from memory. Layer height, speed, retraction, and temperature are easy to misremember mid-print.
5. Avoid jump cuts during the failure itself. If something goes wrong between two clips, viewers may assume a cause that isn’t accurate. A continuous take, even a longer one, is more trustworthy than an edited highlight reel.
6. Add a short written summary with timestamps, even a few lines: what changed, when the failure started, what was already tried. This saves back-and-forth in the comments.
Some people plan out shot order and overlay text before recording, especially for longer troubleshooting sequences with multiple angles. For that kind of pre-planning, a prompt-based tool like Muse Video can be useful for sketching out a shot list or explanatory overlay structure, since it’s built around describing subject, motion, camera treatment, and audio direction together. It’s worth noting the underlying model is still in a preview stage, so it shouldn’t be treated as a finished or fully public tool, and there’s no confirmed integration with Creality hardware or slicers.
None of this replaces posting your actual gcode or slicer profile when asking for help. But a clean, unedited clip with the right shots saves everyone time, including yourself.
