After clearing a blog of death, my sparkx i7 calibrates with the nozzle too close to the bed so the filament cannot adhere to the base
After clearing a blog of death, my spartx i7 calibrates with nozzle too close to plate. It just drags the filament around the plate and stacks up on the nozzle. I tried washing my plate with dawn and flipping it over. I also tried the following:
Since you’ve already cleaned the plate, performed a factory reset, and recalibrated, but the nozzle remains too close to the plate, here are some additional steps you can try based on the printer’s design and maintenance guidelines:
  1. Check the Print Plate Condition:
    • The i7 uses a textured PEI print plate. Over time, adhesion issues or surface wear can affect leveling accuracy.
    • If cleaning the plate does not help, consider replacing the PEI plate with an official SparkX Print Plate.
  2. Inspect the Hotend Assembly:
    • Ensure the hotend is properly seated and the quick-release hotend is fully installed without any misalignment.
    • Sometimes, if the hotend is not fully seated, the nozzle position can be off.
  3. Verify Z-Axis Motion System and Belt Tension:
    • The Z-axis uses dual lead screws synchronized by a timing belt with tensioners.
    • If the belt tension is off or the lead screws are not synchronized, it can cause incorrect nozzle height.
    • Adjust the belt tensioners as per the i7 Belt Tensioning Guide.
  4. Check for Firmware Updates:
    • Make sure your printer firmware is up to date, as updates can improve calibration and leveling routines.
  5. Perform a Cold Pull Cleaning:
    • Even if the nozzle looks clean, residual filament inside the hotend can affect extrusion and leveling.
    • Follow the Cold Pull procedure to thoroughly clean the hotend and nozzle.
Any suggestions?
