AL0506:AI LiDAR calibration failure
HI when I use the AI LiDAR the laser line is projected too far forwards of the stick but still lights up on the bracket. The LiDAR is correctly installed and lights and laser fires it appears that the print head is to far forwards. Are the and adjustments or calibrations for position ?? My K1 Max is rooted and is running the latest CFS upgrade firmware without any other issues i.e. 34.
Any thoughts.
Solved. I replaced the bed and the height of the sensor sticker is too low. So i need to raise the bracket level with the bed.
