When I try to use Cura’s Extension “Pause at Height”, when the print gets to the target layer, the print head moves away, then returns immediately (no pause), a few seconds later I get a 2111 error.
Anyone have success doing this? If so, please send a copy of the “Pause at height” settings.
Cura also has an extension “Change Filament” which I have not yet tried…
I have only used Creality Print 5 and Orca with my Ender 3 V3 and after slicing I move the slider to the layer/height I want and add a Pause there, then slice again. All the slicer has to do is add PAUSE at the layer, nothing else, then you can do filament swap using extrude/retract from control panel, then hit the play/pause icon and resume the print
Jeremy,
That should be easy to do, Cura has the ability to add GCODE before and after, so I can insert the PAUSE.
p.s. It appears that I’ve configured Cura to insert an M0, which is a user stop, which sounds similar to a PAUSE. Not sure why M0 is not being interpretted correctly by the Ender-3 V3…
Are you setting the layer to change filament using the setup in cura? If so, cura inserts M600 in the g_code. Creality version of klipper does not recognize M600. To use this you will have to add the M600 macro to the print.cfg or gcode_macro.cfg file.
