Arc Fitting in process profiles for Klipper based machines
Maybe there is a better place to post this for CP programmers. The issue is that slicer process presets have “Arc Fitting” selected for machines running Klipper firmware. e.g. E3V3 (CoreXZ), K1, K2, etc. This should be unchecked as Klipper. Klipper converts the arcs to line segments and executes the resulting gcode. You’re taking line segments, converting them to arcs, then converting them back to line segments. This adds processing time as well as resultant poorer quality. If you curser over the Arc Fitting option, Creality even recommends that klipper users uncheck the box. When they send out process profiles for specific Creality machines that they know run Klipper by default, this box should be unchecked by default. Please Creality, next time you update profiles, please uncheck Arc Fitting for appropriate machines.
Regards,
I think they need more astute programmers.
