Artster12345
Greetings. Thanks in advance for any reply.
New Halot Mage S. Stage shudders on the way down starting 4 inches from Z Zero. Smooths out as the stage nears the resin bed. Seems to impact taller prints.
All connections seem tight. The stage moves upward smoothly and without issue. Have not looked at Firmware. Screw is lubricated but not excessively so. Screw does not feel rough. Top bearing seems tight, but I will recheck slides and bearing.
Stepper motor issues?
Thanks for thoughts!
Followup - I double checked all screws for tightness. I then applied liberal grase to the screw and rails from top to bottom. I ran the stage its fill length several times, and everything smoothed out. I was able to print a complex part with 100% completeion, something I had failed to achieve in 4 previous tries. By reading this board I was able to learn enough to check and find the actual issue! Good info here!
