automatic shutdown of the k2 printer after printing?
Dear developers! Is it possible to fix or add to the firmware so that after printing, after everything has cooled down, the printer turns off. At least lights and fans! Or, for example, 1 hour of inactivity - everything (fans and lights) turns off automatically. I don’t mind the electricity! I feel sorry for the resource of fans and the fact that they drive dust)
I used to use a smartplug on my printers to turn them off when I wanted to.
that would be awesome. And if we could add automatic door opener, bed changer, and restart print. 24/7 printing. :wink: but lets start with power off
You made it sound like I’d requested a trip to Mars. 99% of devices have this feature. Even cars now turn off their engines when stopped. Developers only need to implement two lines of code, and they won’t need to use additional smart devices, outlets, or worry about it.
On my K1c I used a TPLink wifi switch to shut down the printer approximately 4 min after completion of a print.
I had rooted the printer and installed moonraker and fluidd.
this is the mods required to operate the tplink.
In moonraker.conf :-
[power printer]
type: tplink_smartplug
address: 192.168.0.172 ‘use the IP address of your smart plug
restart_klipper_when_powered: True
restart_delay: 3
port: 9999
In gcode_macro add :-
[gcode_macro POWER_OFF_PRINTER]
gcode:
{action_call_remote_method(“set_device_power”,
device=“printer”,
state=“off”)}
[delayed_gcode delayed_printer_off]
initial_duration: 0.
In the End print macro add the last line :-
[gcode_macro END_PRINT]
gcode:
Qmode_exit
EXCLUDE_OBJECT_RESET
PRINT_PREPARE_CLEAR
M220 S100
SET_VELOCITY_LIMIT ACCEL=5000 ACCEL_TO_DECEL=2500
TURN_OFF_HEATERS
M107 P1
M107 P2
END_PRINT_POINT
WAIT_TEMP_START
M84
UPDATE_DELAYED_GCODE ID=delayed_printer_off DURATION=300
Unfortunately creality has hidden the moonraker.conf file in the K2 printers and is not accessed by fluidd.
May be there is some one who knows how to access moonraker in the creality file system.
Bill
In the Fluidd System section of the GUI, you can download the Moonraker log and in the log it says: config_file: /usr/share/moonraker/moonraker.conf
you can hit ssh on the standard port from a Unix box where you are root and use the default creality password (unless of course you changed it) . For the K2 Plus that was creality_2024
As you might expect, /usr/share/moonraker/moonraker.conf was right there.
One note, Moonraker is the API interface to Klipper. It is very heavily used on K2 systems. Moonraker is how Klipper talks to Fluidd and the “Print” UI.
