I bought a creality falcon 10w laser engraver last year in December and the X axis keeps on losing size. Even after repeated calibration in lightburn in machine settings tab. the machine corrects and cuts like it should for a few passes then starts losing size again. I have checked the belt tension and its just tight enough to allow the x axis to move under gravity. i need to recalibrate the x axis everytime re start the machine and this is extremely frustrating. Please help me solve this
Did you store the GRBL settings? Like when you enter $$ in the console, does it have the steps / mm set correctly there?
But usually these don’t really need to be calibrated since they can be calculated and should be set correctly.
