Bad adheasion
Hi im pretty new to 3d printing, but have made som smaller beginner stuff on my ender 3 S1 pro.
I trying to print a box, but the pla won’t stick to the bed. Im leveling before EVERY (which I also thinks is strange) but I more or less always have to correct it.
I have also wiped it with alcohol, bit it is as I won’t stick properly, and the nozzle is also dragging filament, so the squares don’t come out even.
It’s set to 200/60.
I have tried in print z correction (both directions) but it does not change very much.
Help would be highly appreciated to a newbie
Your nozzle is too high, I would say 0.1/0.15mm adjust the z-offset it should come out much better.
Hi Allan, good morning. If your problem is ONLY adhesion on the print bed, it may sound strange, but try applying a solution made of water and sugar. That’s right, water + sugar. A spoonful of sugar diluted in half a glass of water. Mix well until the sugar disappears and you will notice that the water will turn slightly yellow. Heat the printing table to the printing temperature and apply two coats. Let the first coat dry (the time should be no longer than one minute) and then apply the second coat. Try to make it uniform. Then tell us about the result.
Hugs.
