Bed mesh leveling
Hey folks,
So I had manually calibrated my bed mesh to about 0.38 variance and after a few test prints, it was back to 0.49. Is this due to auto-leveling or does the shift happen due to movement? Having a heck of a time dialing in this k2 for a bit now but not giving up!
Thanks a lot in advance!
My experience is that bed mesh changes when you remove parts from print plate or the print plate itself over the day.
When you switch on the printer it’s calibrating the bed level by moving it several time to ground, this is normally not done afterwards during further prints and therefore when you manually touch the plate too much it looses this calibration which then adds to the original bed mesh.
If you calibrate your bed with screws do it just after the printer switched on and calibrating the bed first time. This way the good mesh should be back at least again when you power on the printer.
By the way, I had once a problem with the print plates, on the left rear side it happened some times that I put the plate on top instead inside this ‘corner’ which resulted to a bed mesh with > 0.9mm variance! Since then I am carefully moving in the print plate to its right position on the magnetic bed and not on the guide.
Wow! Thank you! That confirmed something else for me possibly - the bed being “off” by maybe 1/8" on the left side front, instead of occupying/filling the entirety of the magnetic bed. As a matter of fact, as I’m typing this I’m realizing I should just attach a picture.
Yeah, I’ve noticed due to the ‘snap’ which happens when you put the plate back on, it’s fairly easy to get the position just a little off.
can you elaborate on this please. do you mean manually adjusting the screws under the bed to manually adjust the default layout ?
FYI I’m looking for options/methods to get a more level bed mesh, as I’m printing 4 foot long joined parts which with even 0.6 variance makes for large gaps/problems on larger connected prints.
I’m at the point of either new build plates or going down the glass bed route, so tips on getting a more level bed appreciated.
Cheers
Chris
Ok, printed a knob - leveling thing 3D Printer Files | 3MF File | K2 Plus bed level adjustment knob | Creality Cloud
managed to get my Taco bed down to this (ignoring front left which is cr*p and can’t go any further:
what are others managing to get via default K2 hardware ?
