Has anyone seen this. the last time i checked the mesh it was okay but not great now its crazy i will be adjusting the belts to try to fix.
But has anyone had anything simila
r or know of fixes or would i need a new bed?
Hello @Karl_Young ![]()
That’s really way off.
I would check under the build plate to make sure there is no piece of plastic or something causing the plate to raise up at the back… or maybe a belt slipped off a gear underneath…??
Hello, i have just finished adjusting the belt underneath and am testing again now. I also changed the build plate there was nothing underneath it. its much better now not really flat but I’m trying a few other things atm.
Just curious how much did you have to adjust the belt and what made it go so far out of adjustment when you said the mesh was normal before… ??
