Best Creality 3d Printer for Printing - Expert Recommendatios
I researched about the best Creality 3D printers for the past few days because I want a reliable machine for home use and small projects. I checked reviews on The New York Times, Consumer Reports, and Popular Mechanics, and they are highlighting these two as top choices:
Creality K2 Plus Combo 3D Printer
https://www.amazon.com/Creality-K2-Plus-Combo-Full-auto/dp/B0F5HJMMT
Creality K2 Combo 3D Printer
https://www.amazon.com/Creality-Multicolor-Printing-Leveling-Next-Gen/dp/B0FC2CZ
However, I’m having trouble deciding which one would best suit my needs and I need your expert advice.
I plan to use the 3D printer for general-purpose printing like small prototypes, household items, and some detailed models. I want something that is easy to use, reliable, and gives good print quality. Speed is a plus, but I also care about consistency and durability.
So which one should I buy? Any recommendations will be appreciated. Thanks in advance!
I can’t really recommend one machine over another, but here are a few things to think about:
The K2 Plus is a fairly large machine, so it’s worth measuring your workspace before buying. Make sure you account for the printer itself and any extras like CFS units.
You might also want to think ahead on materials. If you plan to move into filaments like ASA or ABS later, those usually need a heated chamber. The K2 Pro and K2 Plus have one, but the K2 does not.
For storage, the K2 Pro and K2 Plus both have 32 GB of internal memory for files, while the K2 has 8 GB.
For reference, I use a K2 Pro with a 300 × 300 build volume and a heated chamber. Since you mentioned smaller projects, the K2 Plus might be more printer than you really need.
Depends on your budget and the maximum size you need (build plate size) also to consider if you need an enclosed machine (in future if not now). I have a Creality HI, a Sparkx i7, K2 Pro, and K2 Plus.
I preferr the K2 Pro since they seem to have learned a few things on the K2 Plus. The Creality Hi has been very consistent in prints as has the K2 Pro. The Creality Hi is much cheaper.
Also, consider a cheaper machine while you learn and then you can by the machine you want.
You will want to define your needs more clearly before anyone can give you a good recommendation.
If you want something that behaves like a kitchen appliance or an office laser printer, that still does not really exist in consumer 3D printing. The hobby has improved a lot, but you still need to learn the machine, the slicer, and the materials. If your priority is the closest thing to set-it-and-forget-it, Bambu is the stronger choice.
Also, be very careful with mainstream review sites. In my opinion, publications like NY Times, Consumer Reports, and Popular Mechanics are not merely weak on 3D printing, they are often dangerously bad for beginners because they package shallow understanding as trustworthy advice. A naive reader sees a famous brand and assumes competence. What they are often getting instead is watered-down guidance from writers who do not understand the machines, the slicers, the materials, or the failure modes well enough to be steering buying decisions. In a hobby this technical, that is not harmless. It is how people get talked into the wrong machine for the wrong reasons.
I own both a Bambu Lab P1P and a Creality K2 Plus. Bambu is much closer to an appliance-like experience. The K2 Plus, in my opinion, has too many design issues and half-finished features for me to recommend it as a first printer. I am probably more tolerant than most people when it comes to repairs and workarounds, but that is because I accept tinkering as part of the hobby. If you do not want to tinker, Creality may not be for you.
That said, I personally will not buy another Bambu printer. Creality is not perfect, but it gives me more freedom to modify, repair, and customize the machine. Bambu has moved much further toward a closed ecosystem, and I do not like that direction.
As for the K2 Plus specifically, it is a very large machine. Do not underestimate that. It takes up serious space and visually dominates the area around it. The large build plate is useful, but it is overkill for many first-time buyers. Also keep in mind that the CFS requires it’s own space, even if you place it on top. If you get more than one, that’s an additional concern.
My advice:
Do not spend more than $400 on your first printer. Buy a starter machine, learn what matters to you, and then upgrade based on experience instead of marketing.
Here are the open-frame beginner models I would look at, all with build areas around 250 mm or larger:
Model Price
Anycubic Kobra 3 V2 Combo $299
Bambu Lab A1 Combo $399
Creality SPARKX i7 Combo $399
Anycubic Kobra X Combo $449
Creality Hi Combo $449
If you think you will eventually want to print more demanding materials, that matters too. PETG is usually fine on an open-frame printer. ABS and ASA are where an enclosure becomes much more important because they are more sensitive to temperature swings and warping. ABS also gives off fumes, so ventilation matters.
For enclosed multicolor printers, I would consider these:
Model Price
Anycubic Kobra S1 Combo $499
Bambu Lab P1S Combo $549
Creality K2 SE Combo $499
