Best Creality 3D Scanner for Accurate 3D Printing Expert Advice
I researched about the best Creality 3D scanner for the past few days because I need one for 3D printing, reverse engineering, and scanning mechanical parts. I read reviews on YouTube, Reddit, 3D printing forums, and tech review websites, and most users are recommending these two Creality scanners as the best options:
Creality 3D Scanner CR-Scan Raptor Pro for 3D Printing
https://www.amazon.com/Creality-CR-Scan-Raptor-Pro-High-Speed/dp/B0DT422KGY
Revopoint MetroX 3D Scanner for 3D Printing
https://www.amazon.com/Revopoint-High-Precision-Scanning-Engineering-Prototyping/dp/B0DM5GC5WW
However, I am having trouble deciding which one would best suit my needs and need expert advice.
My main use cases are scanning small to medium-sized objects, car parts, 3D printer components, and household items. I need good accuracy, easy software, and reliable results for 3D printing. Portability and scanning speed are also important for me.
So which Creality 3D scanner should I buy?
Any recommendations or real-world experience will be highly appreciated.
Thanks in advance.
Watching this post.
You definitely want a scanner from the Raptor or Sermoon series, not an Otter or Ferret, because you mainly wont to use it for reverse engineering mechanical parts.
How big are your medium sized parts?
The main advantage of the Raptor X and the Sermoon scanners is that these have cross laser lines, that allows you to scan much faster if the object is on the larger side. In the highest detailed mode they also use the 7 laser lines, like the Raptor (non X). So if you parts are max. 30-40cm or so, I would get the Raptor (non X) because it will pretty much do the same for you. The Sermoon scanners which are even in a higher price range than the Raptor X are even faster and have a single laser line mode which is good for scanning deep holes, that is quite useful but the price is also significantly higher. The software is always the same, Creality Scan 4.If the car parts are not too large, I would probably get the Raptor + the Scan Bridge (because you mentioned portability). If you have larger parts like whole fenders, doors or so of cars, the Raptor X (also + Scan Bridge) would be worth it.
