How did i make this solid mounted- Side Mounted Filament Dryer that Replaces the Open, exposed filament side Roller on the K2 printer series or any other enclosed printer with an exposed roller system that can bear weight and is near the filament entry tube?
Because the k2 plus has a open roller with a second part (the metal filament guide) sticking out from the side it gives 2 support areas where the dryer can sit upon or mounted. I WILL BE SHOWING PHOTOS.
I use the roller as support and 10 pound strength “SCOTCH MOUNT EXTREME” ALL PLASTIC “FASTENING VELCRO” to hold it onto the side of the printer enclosure and some Velcro placed on the filament guide bar and bottom of the dryer to keep it from slipping off at it’s base.
here are the photos:
That is a very nice way to get the single spool dryer right next to the printer. In my shop, I have moved the buffer from the back to the upper right corner of the printer, mounted with Velcro because gaining access to the back of the printer is very difficult. This makes swapping from the spool feed back and forth with the CFS(s) very convenient. I located the dryer on the counter right next to the printer. I have been working with TPE filament (that TPU is made from) which soaks up moisture like a sponge. Wet TPE, is almost unusable.
Nice practical setup. One thing to watch with a side-mounted dryer held by Velcro is that a full spool plus heat can make the adhesive or Velcro creep over time, so a simple safety tether or small shelf lip would keep it from dropping. For the TPE, I’d start with the filament maker’s low-temp drying range and verify the dryer’s actual chamber temperature, since TPU/TPE can soften or deform if it runs too hot.
