Hi everyone!
I recently replaced the stock 0.4 mm nozzle on my Creality K1C with an official 0.2 mm nozzle because I’d like to print smaller and more detailed parts.
I created a custom printer profile in Creality Print, changed the nozzle diameter to 0.2 mm, and adjusted the layer height limits. However, I’m unsure which other settings should be changed to get the best print quality.
I’m mainly interested in high-detail prints, so speed is not my priority.
I’d like to know what settings experienced K1/K1C users recommend, especially for:
Line width
Layer height (0.04 / 0.06 / 0.08?)
Maximum volumetric flow
Print speeds (outer wall, inner wall, infill, top surface)
Acceleration
Retraction distance and speed
Cooling settings
Wall count
Top and bottom layers
Temperature changes (if any)
Any other settings that should be adjusted specifically for the 0.2 mm nozzle
If anyone is willing to share their Creality Print profile or screenshots of their settings, I’d really appreciate it.
Thanks in advance!
I do not have a specific profile, but with chatgpt this came out, hope it helps:
Here’s a concise recommended-settings checklist and reasoning for using a 0.2 mm nozzle on a Creality K1 / K1C focused on maximum detail (speed deprioritized). Note Creality Print includes built-in calibration tools (nozzle/flow/tower, e-steps, and dimensional calibration) — use them after any major change.
Basic principles
Treat line width ~ 100–120% of nozzle diameter for best extrusion consistency. For 0.2 mm nozzle use 0.20–0.24 mm line width for single-nozzle lines; 0.24–0.28 mm can be okay for infill/solid walls if needed.
Keep layer height ≤ 50% of nozzle diameter for good layer bonding and detail. For 0.2 mm nozzle that means max ~0.10 mm; for highest detail use 0.04–0.08 mm.
Slow down to allow accurate extrusion & cooling — detail favors lower speed and lower acceleration/jerk.
Specific recommended settings
Nozzle diameter: 0.20 mm (match in Creality Print profile).
Line width:
Perimeter/outer walls (single thin features): 0.20–0.24 mm
Inner walls: 0.24–0.28 mm
Infill: 0.28–0.32 mm (or leave at default if flow is tuned)
Layer height:
Maximum volumetric flow:
Calculate: volumetric = layer_height × line_width × print_speed.
Keep under 8–10 mm^3/s for small-hotend setups; conservative: 6–8 mm^3/s for reliable fine-detail with stock Creality hotend. Reduce if you see under-extrusion at higher speeds.
Print speeds (target slow for detail):
Outer wall: 20–30 mm/s (even 15–25 mm/s for ultra fine surface)
Inner wall: 25–40 mm/s
Infill: 30–50 mm/s (can be higher if volumetric flow limit ok)
Top solid: 20–30 mm/s
Support/bridges: 20–35 mm/s
Acceleration & jerk:
Print acceleration: 500–1000 mm/s^2 (lower is better for quality; stock often higher)
Wall/outer acceleration: 300–500 mm/s^2
Travel acceleration: 1000–2000 mm/s^2 (can be higher)
Jerk / instantaneous speed: keep low if available (e.g., 8–12 mm/s)
Retraction:
Distance: 1.0–3.0 mm (direct drive on K1/K1C: start ~1.0–1.5 mm)
Speed: 20–40 mm/s (start ~25–30 mm/s)
Enable coast/extra restart if needed to reduce blobs
Cooling:
Fan 100% for PLA on small layers; for very thin layers keep fan high to prevent heat creep
For PETG/ABS reduce fan (20–50%) and increase extrusion temp; use enclosure for ABS.
Minimum layer time: 8–20s for small features (use slow speeds or enable extra cooling/wipe)
Wall count / shell:
- Use 2–3 walls depending on object geometry. For fine outer detail 2 walls with correct line width gives best surface; 3 walls for strength.
Top/bottom layers:
Temperatures:
PLA: start 195–210°C (use lower end for detail, higher for better flow). Tune by small increments.
PETG: 230–250°C
ABS: 240–260°C (use enclosure)
If under-extrusion at slow speeds, raise temp 2–5°C; if stringing, lower 2–5°C.
Flow/Extrusion multiplier:
- Calibrate with a single-wall and 20 mm cube. Fine-tune 97–103% as required.
First layer:
- Keep first layer slightly thicker for adhesion (0.12–0.16 mm) and slower (10–20 mm/s).
Travel/ooze control:
- Enable combing where appropriate, Wipe/Coast, and Z-hop only if needed.
Support:
- Use tree supports or low-density supports for delicate parts; thin interface layers for clean removal.
Tuning checklist
Update Creality Print profile: set nozzle and filament diameters, line widths, layer height limits.
Run Creality Print built-in calibration tools: extrusion/flow, temperature tower, bridging test, dimensional calibration.
Print a 0.2 mm-specific calibration cube and single-wall test: check line width, gaps, and over/under extrusion.
Print small detail test (mongoose or benchy details, fine-gear test) and adjust speed, temp, flow, and cooling iteratively.
If ringing/ghosting appears, lower acceleration and jerk further.
