Binding the K2
How to bind the K2 if you screwed it up on in initial setup?
Hi,
you mean, how to find the QR code again ?
Thanks for getting back to me. I did finally get that done but my main issue is that I am having a problem trying to print from the CMS with the CMS installed it acts like the extruder wont retract the filament and than the CMS will pull it tight untill it wears a hole in the filament. I have these codes CM2788,CM2784, FB2847,FR2836, FB2864, FS2848 and FR2849. the pinter seems to work fine with the side spool and I have updated the firmware and had no issues doing that. I also sent in my log history.
I see, when i read “bind” i thought about binding the K2 to your Creality Cloud.
Well, with your collection of error codes this looks like a case for creality support, did you contact them ?
