Biqu Cryogrip Buildplate K2 Plus
So I bought the 350x350 Glacier Pro plates for my k2 plus’s and although they don’t fit perfectly, they work. It’s about a quarter inch short in the rear and maybe 3/8” short on each side. So you’ll need to change code to make it perform nozzle wipe a little bit forward. But it’s worth it. The adhesion is too notch. Trust and believe.
I have a couple en route for my V3SE and V3KE just to experiment with. Interested to see if they outperform my favoured Fysetc build plates, I have those on all my printers. If the cryogrip works I might upgrade the rest of my printers.
I got the 356x356 plate and love the adhesion. I put the plate all the way back and have no problems. Initial xy pass is off the plate but that is not a problem.
Everything seem to stick well.
I also went to hardware store and had them cut some glass to 370x370 and got a real flat build plate config.
Had to print some screws to hold the plate as the clamps get warm and do not hold.
hi. where must i change the code. i dont find it
