Hi,
Thank for your answer but I have try to enable On/Off the dark mode and it’s not working…
The problem is the same with Bambu Studio and I wonder if this does not come from a problem with a common base in the code of the two slicers (if we assume that both use the same Open source base).
Yes, Win 11 and Dark mode, no effect. That look like my computer does not want to display the space dedicated to the visualization of the 3D board and the 3D model. All 3D software I using work perfectly.
Solution found, I post here for those who will encounter the same issue .
Apparently I wasn’t the only one affected by this problem. I was able to find a GitHub post (linked) where a user reset the settings of his AMD Software.
I downloaded from the AMD site: AD SOftware Adrenaline, during installation I specified to reset to factory settings.
Deleting the previous driver and OpenGL and installing the new one and OpenGL allowed me to return to normal operation with the latest versions of Bambu Studio, Creality Print V6.0 and OrcaSlicer.
