Hello,
I have the K2 Pro Combo and keep getting the error message BM2355.
Can anyone help me here in the forum?
Best regards,
Stephan
Hello,
Best regards,
Stephan
Hello @Elimar2004 ![]()
I don’t know if this helps but the cable to the hot end seems to be a weak link on some of these printers causing the MCU communication error.
I have the K2 Pro Combo and haven’t had that error yet.
Creality has a video here
K2 Pro Hotend Adapter Cable Replacement
You might not have to replace the cable but the video shows the parts that might need to be checked for looseness.
Brand new K2 Pro here, will not pass initial setup and calibration with same error BM2355 MCU error.
I just started getting this BM2355 error today and have had some success in solving it by popping off the print head plastic cap/cover and adjusting the thin wires. I straightened out the wiring to point up instead of going at a hard 90 degrees. This post provides some more details. https://www.reddit.com/r/Creality_k2/comments/1nbsouv/i_have_created_a_possible_solution_to_the/
I did not create a physical attachment, I simply pulled the wiring out a little and adjusted them so they were pointing in a vertical direction instead of horizontal direction.
