This is “Boxing Board” design model, which is based on strategic play. This model is designed on real time strategic play, as you can give real body movement (front, back, side, tilt and rotate) to character.
It supports all direction movement except up & down which allows player to plan strategic punch. The Correct master punch will drop down the head of opponent and will collect the points round by round. Final max point player will win the match.
Description :
- Boxing Board-Strategic Tournament.
- Real time play Design.
- All direction moment (front, back, side, tilt and rotate).
- Rough & tough Design.
- Simple to operate.
- Can be played from +4 to any age.
Print Parameters: (Common)
- Slicer Software : Creality Print
- Printer: Ender3 KE.
- Profile mode: Normal Quality (0.2mm)
- Infill: 30%
- Scale: 100%
- Retraction: 2mm minimum.
- Print Speed: 300mm/s.
- Printing Temp: 220 0 c.
Time for printing : 14Hrs (Considering all Situation)
For Assembly please follow doc file in model link,
Creality Cloud -'Boxing Board- Strategic Tournament" From PurushottamSS Exclusive 3D Prints | 'Boxing Board- Strategic Tournament" | Creality Cloud
Here i am sharing video of my kids play,.,
Please follow and support if you like my work, Your support is valuable for me.
Thank you all…!!
