Brightness
How to set the brightness of jour Creality Hi 3d printer.
At startup the brightness is ok ?
Same Issue , Bright LED on Startup then the light dims once the system takes over, obviously a setting.
I have not found the solution yet but I’m searching.
Anyone get any updates on this? This is definitely firmware related and not simply a setting that can be changed, although it should be.
