C Print V5.1.7.10514 BUG selecting 0.6 nozzle
I have a K2 combo and its been working fine with 0.4 nozzle and the above software.
I created 3 user filament configurations and, as above all printed fine.
With a clean build plate and K2 plus 0.4 nozzle selected my User filament selection is there. When I change selection to 0.6 Nozzle it disappears.
Selecting the CFS filament and editing comes up with a blank set of tabs , so therefore unable to create anything.
Anyone found a work around ?
Found a work around:-When selecting your filament (CR top right):-
a) hit drop down arrow
b) Select add/delete
c) Tick check all in both sections.
Now the CFS will NOT default to PLA from whatever was previously entered by User.
Now you can edit the filament and create a User configuration for your filament.
Next time your change nozzle size all should be there.
@Optimus Be grateful if you could send to developers please. Could be same for 0.8 nozzle?
I still don’t belive the saving and re presenting of User filament configurations is robust though.
