Can i upgrade to a 20w module on my Falcon A1
I only bught my Falcon A1 a few weeks ago and im really happy with it , my question is , can i upgrade the 10w module to a 20w ? Ive looked everywhere and cant seem to find anything on them .
The 20W module of the Falcon A1 Pro is completely different and can’t be fit in the A1 (it does not have the quick swap connector). However the 10W has some advantages, it is quite good at fine engraving (more wattage β†’ more diodes β†’ bigger laser spot), only the cutting speed would be better with 20W.
Thank you for the info . I will just stick with the 10w laser for now . :+1:t2::+1:t2::+1:t2::+1:t2:
Hi Philip. I just try to read your message about laser Module 10W to 20W but your profil is blind. Can you tel me if it is possible to put a laser module 20 on my creality facon A1 . best regards JAY
Not directly, I mean just could probably reverse engineer it and tinker one on, but the 20W module of the A1 Pro has a different electrical connector and a different mechanical mount and is not directly compatible.
Thank you very much
