Can I use an extra (External single spool of filament) on a K1 Max with CFS? If yes, how do I connect it?
Yes you can but you cannot use it in conjunction with the CFS. You have to manually load the filament and extrude it before you can print with it. Make sure before you print you choose side spool
Thank You for that quick answer I will try that
No Problem good luck.
