I recently updated Creality Print to the latest version and since then I’ve had the following problem: I can’t import any .stl files anymore. I open the corresponding folders, but no files are shown there. When I try to drag the files from Explorer into Creality Print, that doesn’t work anymore either (I’m pretty sure this used to work without any issues).
If I open the files with a double-click, Creality Print launches and the STL model is loaded without any problems, but only a single one. If I open multiple files at once, a separate instance of Creality Print opens for each STL file.
It’s slowly driving me insane because I have absolutely no idea what could be causing this! Help!
I have the same problem. Creative Cloud is unlogical and extremely difficult to use. Would it be possible to use some third-party software where the interface would be a USB stick to the printer itself?
@Jokka_Pekinen Are you using Creately cloud or creately print 6? If you are using Creately cloud in a web browser, I agree 100%, but the software version that runs on a local computer (PC in my case) runs MUCH better and is much more intuitive to use. I haven’t used the cloud version in so long. Does it even have roll over help yet?
