Can't select external spool in new Creality Print 6.0.2.1574
Have external spool set as gray Creality Hyper PETG on my K2 Plus. Cannot select the external spool “EXT” nor does the auto mapping transfer the external spool configuration in the new Creality Print 6.0.2.1574.
You can change to the external spool when sending to the printer, but it shows PLA and there is no way to change to the correct filament. The software thinks that it is PLA and there is no apparent way to change to PETG. Tried with the CFS connected and disconnected.
Had to go to the last CP 5 that I had installed to attempt the print using the external spool with PETG.
As far as I know you can print but with a different logic!
You select a filament from the list for the part to print (it uses normally 1st filament for new parts).
Then you change the type of filament like here where I set it to PETG:
Then you print send it to printer but switch to spool holder like here:
As long as the CFS is connected it will default to CFS and you have manually to switch to spool holder.
Thanks.
Had to change CFS slot 4 to hyper PETG, slice, and then select spool holder when sending to the printer. Not really an intuitive approach by Creality.
Plus there is no notification from Creality Print that there is a mismatch in the file to be printed and the type of filament when it was sliced for PLA and PETG was the filament on the spool holder and entered into the K2 Plus.
Hello,
I have the same problem with CR-TPU, which doesn’t work in CFS. But I can’t select CR-TPU and then slice it and then print from the spool.
How can I print CR-TPU via the spool holder?
Thanks
Click on the Setup Gear in the upper right hand corner of Creality Print.
Scroll down, click on CR-TPU and confirm.
Now CR-TPU will be available to choose from your CFS spools listed.
Follow frank’s post above to slice and send to printer for the spool holder.
Thank you for the tip.
Since I come from Germany, I had set Creality Print in German. In the German settings, all of these filament types don’t exist at all:
I then switched to English and there are already many more types of filaments:
The printer does not seem to support external spool printing while the CFS is enabled without some significant headaches. I would love to use my CFS more if it was reliably feeding filament, but it is not, so I use the spool holder instead, but I have to disconnect the CFS from the back of the printer to get it to work at all, still
Hi, I have the same problem - I just wanted to add an additional spool via the external holder. I tried setting it up in Creality Print using the gear (settings) button in the upper right corner.
When selecting the pencil button, I chose the brand → Generic, but when trying to select the type, the menu resets to the default values, preventing any selection. This has to be done on the printer screen instead. Once set there, the brand, color, and type are correctly displayed in Creality Print.
Weird - definitely a bug that needs some tweaking! :wink:
Same issue here, it locked me out of the spool holder when I wanted to try the custom BIQU PLA HR filament and made me select PETG just to print. Talk about annoying, please update your software Creality and make a functional and user friendly GUI. This is not okay.
I had the opposite problem - slice and send to printer, and CFS wasn’t available and was forced to use external spool. Ended up being some sort of glitch or bug - restarted the printer and it then saw the CFS. C’mon Creality, seriously?
Yea I’m having the same problem. Want to print PETG with side spool option via the Space Pi + but no option in Creality Print to even choose side spool. Only get CFS, so ended up taking a spool out of the CFS and put in the PETG, put in the settings and print. As for saying there is a need to disable the CFS, how do you do that? No power switch so I just unplug two cable? Thats a farce for a $1,500 printer. I agree Creality needs to fix this.
having the same problem with the spool not being recognised when you goto print had to do the work around that was listed above. thanks for the info help me out alot
but creality should have picked this up lets hope they fix it very soon with an update to creality print 6.1
Set your 1st filament in the CFS as whatever your side spool is that one way to make sure it’s using the same type of filament when slicing. Or go over to global/objects and select objects. Then click on the color number 1. A drop down will appear. Change color there. This way your model is the correct filament and sliced in correct filamemt. Then hit send. Here you’ll be able to choose side spool. And if you didn’t right your file will have been sliced in the correct filament. Because it will always default to the 1st slot for print color and filament.
