CFS - how to use custom filaments and Creality print
Dear,
I just have added a CFS to my Creality K1C. So far I have used the printer for roughly a year in a single filament setup. My approach using this was to calibrate each filament in terms of temperature, flow calibration, pressure advance and finally the maximum volumetric speed.
How can I use these settings with the CFS? If I understand the whole approach correctly, the idea is to set the spools up on the CFS - however, I can just choose between the Creality and Generic as producers and just set a temperature range and pressure advance. If I change the spool definition in Creality Print, it is loosing the connection to the spool.
How do I get this setup working?
Thank you for pushing me in the right direction.
Regards
Gilhin
