CFS Lite Filament Compatibility Guide
Spool Specifications
Compatible with various Creality filament spools, including Hyper Paper Spools / Hyper Plastic Spools / CR Plastic Spools / EN PLA+ Paper Spools.
Compatible with third-party filament spools, such as Rambo, Sunlu, eSUN, and others.
Supported spool dimensions:
Diameter: 195–202 mm
Width: 42–68 mm
Filament Types
Standard filaments: PLA, PLA Silk, PLA-CF, PETG, PLA Glow, and most common filaments.
Flexible filaments: Harder flexible materials such as TPU 77D / TPU 64D.
Not supported: Softer flexible filaments such as TPU 95A, as well as overly brittle or easily breakable filaments.
Notes
Avoid using filament spools that are too wide or too small, too large or too small in diameter, irregular, or not smooth (e.g. with burrs or damage). Deformed spools or spools with abnormal dimensions may increase rotation resistance and cause feeding failures. It is recommended to use Creality Hyper Plastic Spool series filaments, which have been extensively tested.
Avoid using CFS lite to print TPU 95A or softer flexible materials, including TPU 95A, TPE, or moisture-absorbed PVA, as they may get stuck in the CFS lite filament path during printing and cause feeding failures.
Avoid using overly brittle or easily breakable filaments, such as some third-party fiber-reinforced materials (PA-CF/GF, PET-CF/GF, etc.), as they may cause issues such as wear to the CFS lite filament path or filament breakage inside the PTFE tubes during printing.
