Cfs not loading sample filament
Has anyone else had problems for cfs to load sample filaments? Even putting them in regular spool, cfs won’t load and retract them properly. I think it may have to do with its light weight. Bit if that’s the reason, can it also happen when my regular filaments are close to end?
Never had this issue with a near-empty spool.
Could it be that the filament is not tight enough since you’ve put it on a regular spool ?
Hmm, indeed, it is a bit loose, since the samples came without spool and I had to curl it around the spool. Have any tips about what I could do to tighten it?
