CFS Running in reverse
Hoping someone can help out on this one…
Friday morning I received notification of a firmware update for my 2 month old K2 and CFS which I ran with no issues. But now, when I try to do a print or even just an extrude command from the K@, the filament does not feed in to the tube, it actually runs in reverse and the filament retracts all the way out and I receive an error on the CFS. I have tested to make sure it wasn’t a clog or anything or an issue with the buffer, I used the same tube as the cfs with the same filament on the external spool and it was able to extrude with no issues. Is there a way to factory reset the CFS? Is this a known issue that may be addressed shortly?
Mine had that too.
It is thinking there is some filament in the CFS between the top and bottom feeder.
One of the filament detectors has an issue. On the bottom is a pcb with four light barriers.
In my case I was able to heat them up with a heat gut to 40-50°C and the LED turned on for two barriers. So they bend when getting warm and the photo diode on one side is not able to see the other side`s LED.
I bend them slightly towards and since then I am fine.
i think you can doing the actual factory reset for the k2…maybe it also does the cfs as the update for the cfs comes through the k2 second day of me having the k2 i got an update for the cfs it just updated through the k2…not even available on the creality site like the k2 older firmware’s
I’ve factory reset my printer at least 3 times and I still cannot get the CFS to load the filament that came with the printer.
The lights are dancing like they’re supposed to when it’s fully empty. The bottom piece does not light up implying there’s an issue with the sensors.
When I also run an “extrude” command from the printer itself, it waits a minute, runs in reverse and I also get a CFS error.
I might take it apart again to double check the sensors at the bottom.
I had the same issue start randomly. I will have to try messing with the diodes. Mine will also randomly fully reverse and say out of filament.
Any resolution to this? I have one doing this. Feed a new roll, it runs in reverse and spits out all filament. It will not feed a new spool in the first two slots i’ve tested so far.
I have had this plus many other issues all causes by the 5 port circuit board below CFS within the hub. All these various issues appear when then chip (usually no 3) goes rogue - it screws the CFS.
The software cannot handle the exception. Would it be great if you could isolate the offending port or the software automatically isolated that reel until recified.
Changing the 5 port circuit board solves it immediately.
Suggest contact Creality Service for a replacement
@Lu_Zhang
I’m having these same issues with one of my Hi’ CFS. Ahhhh, so frustrating.
Any fix? Or do I have to return the CFS? Same issue here worked fine when I first started using it, now it retracts to far every single time.
