So, I started getting a FR2849 error, I’ve taken the CFS apart as far as I could and I don’t see any clogs. Slot 1 will only feed filament if I press on the tab that you press to pull the filament in and out. Anyone run across this before I reach out to Creality?
I too am having similar issues. Slot 1 was first one with issues. Now all slots will not autofeed. I get errors FR2849 and FR2836. I have disassembled the CFS as far as I can on 3 occasions. I cannot find any issues. Have emailed cs support 3 times and no response. All I can use right now is the external holder.
I also had problems with this last week. It started after I used the external spool and was going to use the CFS system again. It was after this that the problem started. Hope someone can figure out why this is since CFS is useless when it doesn’t autofeed. I have checked the sensors and that there is no filament that has stuck. The spools just stand and pull back then the FR2849 error comes.
