Hi there,
On my K2 plus I often print with different filaments from the side spool. I use PLA ABS PET-G PET-G CF Nylon PA 12 and PA 12 CF. Sometimes I also change the nozzle - most often I change from 0.4mm to 0.2mm when I want to print small parts in nylon. When I change the filament without changing the nozzle I basically have no problems. On the Filament tab, I do Retract, remove the filament, insert a new one and click Extrude. The printer “remembers” what filament was in the nozzle and actually performs the purge with the correct nozzle temperature sequence.
The problem occurs in two situations. When the printer is switched off and when switched on it “forgets” what type of filament was in the nozzle. Changing the filament from the menu does nothing, the printer heats the nozzle to the temperature of the filament it “recognised itself” to be loaded regardless of the settings.
The second case is to change the nozzle with a different filament. I do not know how to “convince” the printer that it has a different filament in the nozzle.
The problem is significant just because K2 nozzles are long and relatively lot of filament remains in them. When there is PLA in a “newly installed” nozzle and the printer, for example, thinks it is PA 12: after clicking the Extrude button on the Filament tab, it heats up the nozzle to 260-270°C, which often for PLA causes heat creeping and a clogged nozzle is guaranteed. Then a moment’s pleasure in unscrewing the extruder, cleaning the nozzle and half an hour passes… What am I doing wrong?
