FYI, just a post to check the wiki updates monthly…
Just in case you’ve performed maintenance for which the instructions have now changed, examples are:
K2 Plus File Package (Click and Scroll to the bottom of the page)
Calibrate K2 Plus Servo Motor (x-axis/y-axis/z1-axis/z2-axis motor) (Updated the contents)
K2 Plus Belt Auto Tension Module Calibration Process (The command lines are updated again.)
Creality OS Error Code: CM2789 (Additional content for specific troubleshooting for K2 Plus/Creality Hi Error Code)
K2 Plus Factory Reset: USB Drive Method Guide
K2 Plus Z-axis Lead Screw Cleaning Guide
K2 Plus X-axis Guide Rail Cleaning Guide
K2 Plus Idler Wheel Noise Lubrication Guide
How to use K2 Plus to print TPU filament (“Filament settings on the screen” content updated)
Creality OS Error Code: AC0104 (Applicable model:Creality Hi/K2 Plus/K1C/K1 Max)
How to prevent K2 Plus Extruder Pneumatic Connector Fail to Secure PTFE Tube?
Replace Extrusion Motor Assembly(New content: “How to confirm if the motor is rotating normally?”)
Troubleshooting for K2 Plus Filament Break Detector Board False Trigger
Creality OS Error Code:TR2852 (Update Content)
K2 Plus Firmware Flashing Procedure (Update Firmware Flashing File Package)
the list goes on…
