Choose filament print order
I have a two colour print that, when I slice, the first layer will print blue, then white.
I’d like the first layer to print white first then blue (thus avoiding any colour bleed from the blue into the white on the first layer). Is there a way to choose this?
So I found the answer myself.
In Prepare, you click the cog icon (settings) to the right side of the build plate.
There is an option called First Layer Filament Sequence that is set to Auto but you can change to Customise, then drag the colours to the sequence you want.
You can then validate the sequence in Preview by selecting the first layer then running through the steps.
