Player ![]()
๐ฏ๐๐ฐ๐๐๐ฒ๐ฟ๐๐ผ๐ป๐ฒ
@3D4Everyone
๐พ๐ค๐ข๐ฅ๐๐ฉ๐๐ฉ๐๐ค๐ฃ ๐๐ฃ๐ฉ๐ง๐๐๐จ:
๐๐๐ง๐ฉ๐๐๐๐ฅ๐๐ฃ๐ฉโ๐จ ๐๐ฌ๐ฃ ๐๐ค๐ง๐๐จ ๐๐ค๐ง ๐๐ค๐๐๐ก ๐ฟ๐๐จ๐๐ง๐๐ฅ๐ฉ๐๐ค๐ฃ:
Itโs printed with on the K1 Max with CR-PLA Matte filament using the Generic filament option in Creality Print but changing the following values.
walls: 2
Infill: Gyroid 10%
Z Hop Height: 0.30
Travel Avoid Distance: 0.80
Limit Support Retractions: off
Enable Jerk Control: on
Support Structure: Tree Slim
Support Top Distance: 0.25
Support Bottom Distance: 0.25
๐๐ค๐ง๐ ๐ฟ๐๐จ๐ฅ๐ก๐๐ฎ๐จ:
My droid army took me months and months and months to build, the tallest is over 6ft. All built on Creality Printers, K1 Max, Ender5Plus, CR10V3, CR6SE, Ender3V2, Ender3, a lot of these printer and filament used were Christmas presents over the last few years. The models were created by Droid Division on Patron. I use the default profiles with the following changes:
walls: 2
Infill: Gyroid 10%
Z Hop Height: 0.30
Player ![]()
๐๐ป๐ฎ_๐ฃ๐ฎ๐๐น๐ฎ_๐ฏ๐
@Ana_Paula_3D
I did the sculpting and printing on an Ender 3 V2 with Sonic Pad in PLA
Creality Print
Layer 0.2
Walls 2
Buttons 3
Top 5
Infill 10% rectilinear
Free supports
Player ![]()
๐๐๐ฑ๐ถ๐๐ฟ๐ถ๐๐ฒ๐ฟ
@AudiDriver
These are my Christmas Prints.
Player ![]()
๐๐น๐ฐ๐ธ๐๐๐ฎ๐ฟ๐ฌ๐ต
@Blckstar09
Printed using my K1 Max
Player ![]()
๐๐ผ๐ณ๐ณ๐ฒ๐ฒ๐ฑ๐๐ฑ๐ฒ๐ฎ๐ด
@Coffeedude28
Hereโs one of our tree my partner is very proud of
Player ![]()
๐๐ฎ๐ด๐ฎ๐ฎ๐ฌ
@Daga20
Made this to hang on my window but it also looks great on my tree.
Used orca slicer with BBL P1S
30 min print at 200 ms
0.2 layer height
Embrio White pla used as a material
Player ![]()
๐๐ฏ๐ธ๐ฒ๐ญ๐ฒ
@Dbk616
Printed on a CR 10s Pro V2 at 50mms with Hatchbox filament.
Player ![]()
๐๐ท๐ฐ๐ฎ๐๐ต๐ญ๐ฐ
@Djcath14
A farm for my daughter to play with.
Player ![]()
๐ฑ๐ผ๐ป๐๐_๐ฟ๐ฒ๐น๐ถ๐ด๐ถ๐ผ๐ป
@donut_religion
A great and simple holiday gingerbread house. Easy to make with two filaments and one nozzle, just pause in the middle change color and start printing again. PLA, 0.2 mm height, 200 c, 15% infill, all default settings in for normal print. Even with a slower printer, it takes less than 2 hours to make and I am sure you can speed it up a lot with no problem.
Using Ender 3 Pro.
Pulled stl from Printables
Player
๐๐ป๐ถ๐ด๐บ๐ฎ๐ฌ๐ฌ๐ฌ๐ฌ๐ฌ๐ญ
@Enigma000001
Fire on logs on a custom base. Fire is lit with an ESP32 driving two neo-pixel panels running code to mimic a flickering fire burning and is USB powered.
Player
๐๐ฟ๐ถ๐ธ๐ฎ๐ฟ๐๐ฒ๐ฏ๐
@Frikarte3D
Itโs my own design, remixed the mechanism of the JamesThePrinter Mechanically Locking Container.
I made it square with a 3 options of snowflake knob, two styles of lids and 4 size boxes.
You can find it for FREE in my @CREALITY Cloud Profile here: Snowflake Mechanical Box| 3D models download | Creality Cloud
Parts are oriented correctly and printed with my K1 with default settings at 0.2mm layer height and 15% infill. Just make sure you check your bridging settings for the lids.
Another Christmas design and print I want to share are my Snowflake Glasses
Give a festive look to your Christmas or Winter party and surprise your family and friends with this stylish festive look!
You can download it for FREE on my Creality Cloud profile here: Snowflake Glasses | 3D models download | Creality Cloud
Player
๐๐ฒ๐ป๐ฟ๐_๐
@Henry_L
Behold the purr-fect embodiment of holiday cheer!
Immerse yourself in the magic of the season with my enchanting 3D printed creationโa whimsical cat, adorned with a snowy white spot on its delicate nose, nestled atop a festive Christmas present, crowned with the iconic red Santa hat.
This charming masterpiece captures the spirit of joy, warmth, and feline mischief, all rolled into one adorable creation. The intricate details of each whisker, the mischievous glint in the catโs eyes, and the carefully crafted folds of the Santa hat bring this delightful scene to life.
Print Setting
Ender PLA Black Transmission Distance: 0.2
Eryone PLA rose Red Transmission Distance: 2
Esun PLA+Yellow Transmission Distance: 2
Ender PLA White Transmission Distance: 1.7Start with Black
At layer #7 (0.48mm) swap to L-EGO Red
At layer #17 (0.88mm) swap to L-EGO Yellow
At layer #27 (1.28mm) swap to White for the rest.Original designer JSFN91
Player
๐๐ถ๐น๐ฑ๐ฒ๐ด๐ฎ๐ฟ๐ก๐ก
@HildegarNN
Bueno, yo comienzo con esto de la impresiรณn 3d, mi primera impresora es la Ender 3 V3 SE y comencรฉ con unas esferas de navidad personalizadas para mi familia.
Para las esferas las diseรฑe en thinkercad, y despuรฉs el modelo lo pase al programa (Creality Print) usando el filamento โCreality Filamento PLA (HP ULTRA PLA Blanco)โ
Parรกmetros utilizados:
layer height :0.1mm
No support
180mm/s
Temperatura de impresiรณn 205 C
Temperatura cama 65 C
(Realmente es el perfil de High Quality que viene por defecto)Para el arbolito asteric, utilice el mismo programa de creality y utilice un modelo que encontre en internet que me gusto mucho, lo dejo aquรญ (Fibonacci Spiral Trees โ Vase Mode V2 por Triple G Workshop | Descargar modelo STL gratuito | Printables.com) y utilice el segundo perfil en el programa que dice normal, solo quite soportes y infill 0%.
๐๐๐ ๐๐ค๐ก๐ก๐ค๐ฌ๐๐ฃ๐ ๐๐ค๐ฃ๐ฉ๐๐ฃ๐ฉ ๐๐จ ๐ฉ๐ง๐๐ฃ๐จ๐ก๐๐ฉ๐๐ ๐๐ฎ ๐๐ค๐ค๐๐ก๐:
Well, Iโm starting with 3D printing, my first printer is the Ender 3 V3 SE and I started with some personalized Christmas spheres for my family.
For the spheres I designed them in thinkercad, and then I passed the model to the program (Creality Print) using the filament โCreality PLA Filament (HP ULTRA PLA White)โ
Parameters used:
layer height :0.1mm
Not supported
180mm/s
Printing temperature 205 C
Bed temperature 65 C
(It is actually the High Quality profile that comes by default)For the asteric tree, use the same Creality program and use a model that I found on the internet that I really liked, I leave it here (Fibonacci Spiral Trees โ Vase Mode V2 por Triple G Workshop | Descargar modelo STL gratuito | Printables.com) and use the second profile in the program that says normal, just remove brackets and infill 0%.
Player
๐๐ฟ๐ถ๐ป๐ฎ_๐ฃ๐ฒ๐ป๐ป๐ฒ๐ฟ
@Irina_Penner
I printed these Crystal dragons in chirstmas colors
Player
๐ท๐ถ๐บ๐ฎ๐ป๐ฑ๐๐ฒ๐ป
@jimandyen
My entry for the 3D Model Competition Gala is this great miniature model of a Christmas Snowball Town inside of a snowball
Printed on a K1 Max.
Creality Print default settings for Silk PLA
Silk White PLA.
Nozzle Temp: 220ยฐC
Build Plate Temp: 60ยฐC
No supports.
Added LED / wiring
Uses either batteries / AC plugCredit Link to the Designer: STL file Christmas SnowBall Town
ใปModel to download and 3D printใปCults (cults3d.com)
Player
๐๐ผ๐ป๐ฎ๐๐ต๐ฎ๐ป
@Jonathan
*Filament petg - buse 235 - plateau 70 - PA 0.04 - matรฉriel flow 98% -3 color red/black/green . Print on Ender 3 S1 , marque du filament - sunlu (a cause du vert fluo)
*Gravure sur verre , vitesse 8000 - Power 60% , 2 pass. Gravure par creality falcon 22w.
*Head cover on resin (3dmaterials -hyper fast white + add pigment) 3 first layers 30 sec - layers 2 sec - off 4 sec - speed 2mms. Print on halo mage + wash and cure with creality uw-02.
Player
๐๐ฒ๐ฟ๐ฒ๐ฏ๐ฟ๐ฎ๐น๐น๐ฒ๐ด๐ฒ๐ป๐ฑ
@Cerebrallegend
๐ฏ๐ฟ ๐๐ค๐๐๐ก:
๐๐๐ง๐ฉ๐๐๐๐ฅ๐๐ฃ๐ฉโ๐จ ๐๐ฌ๐ฃ ๐๐ค๐ง๐๐จ:
This would have been my entry IF I had a printer.
Player
๐๐ถ๐ฐ๐ฎ๐ธ๐ฏ๐๐บ
@Kicakbtm
This is my first Christmas Adornment! After carefully removing all of the supports I dropped it out of my hands and broke off the star
Used Orca slicer with BBL P1S
One pause at layer 2235 to swap filament from BBL Basic green to Creality Silk gold.0.20 layer height to speed things up as I slowed down layer time down to 13 to make sure overhangs are spot on.
142ms and 4k accel.
15% infill.
80% aux fan.
Player
๐๐ถ๐๐ฎ_๐ ๐ฒ๐น๐ฒ๐ป๐ฑ๐ฒ๐
@Lisa_Melendez
I created my images for my cutters in Procreate, I use Cookie Cad to change into stl file.
I print on my Ender3 Maxine and ender3
Pla 1.75 filament
I am really new to this and used Tinkercad to add names to my cutters.
Player
๐๐๐ธ๐ฒ_๐ก๐๐น๐น
@Luke_Null
These were all printed at roughly 60 bed 190-200 nozzle temp, .4 nozzle, mixed PLA, .2layer height,solid infill as they are 7 layers tall, ironing on. Cura slicer.
Anthony Herrera Star Wars snowflakes on cults
Individually about 1.5 hours each. Total I printed 45.
Christmas Gift for my nephew who absolutely loves Pokemon and has a Nintendo switch
Printed on Ender 3v2
Sliced in cura
Filament Creality White + Black, Sovol acid blue/orange
Nozzle .4
Layer height .2
Bed temp 60
Nozzle temp 198
Print time 1 1/2 days
Design found on cults
Player
๐ฃ๐ถ๐ฟ๐ฎ๐๐ฒ๐ฅ๐ฎ๐ด๐ฒ
@PirateRage
One of the things i made was a Christmas themed baby Yoda.
Its is made on a Creality CR 10 V3 , sliced with Cura , Layer height 0.2mm ; wall thickness 1.2mm ; infill density 15% lightning ; print speed 50mm/s ; filament is marble pla ; bed temp 60 deg C and nozzle temp 190 deg C
Stl can be found on โThangs Festive Force Baby Yoda
Since winters are cold in my country we are used to chopping wood. So i printed a viking axe for my father , that may not be good for chopping wood but its a great souvenir. He also combined with pair of skeleton hands and head i printed .
Its is made on a Creality CR 10 V3 , sliced with Cura , Layer height 0.2mm ; wall thickness 1.2mm ; infill density 20% grid ; print speed 50mm/s ; filament is creality CR wood pla for the handle and black for the head ; bed temp 60 deg C and nozzle temp 190 deg C . Funny enough wood filament printed perfectly with my standard pla settings and 0.4mm nozzle
Then i coated the wood with wood stainer and used grey/metallic rub n buff on the axe head.
Stl can be found on โPrintables - Viking Axe with Handle (No Glue Required)โ
Player
๐ฝ๐ฟ๐ถ๐ป๐๐ฒ๐ฟ๐ฝ๐ฟ๐ผ
@printerpro
This is what I made - a christmas elf that I printed on my Ender 3 V2.
Player
๐ฅ๐ฎ๐น๐ฝ๐ต_๐ ๐ฎ๐ฟ๐ถ๐๐
@Ralph_Marius
Made some LED lit Countdown to Christmas Snowmen. Took about 10 to 12 hours to print all the parts with Petg. Temps at 235/65 at speeds 120mm .20. Printed on an Ender 3 S1 Pro with klipper.
Player
๐๐ฏ๐๐ฒ๐ฏ๐ฎ๐๐๐ถ๐ฎ๐ป
@s3sebastian
There he is - finally finished with the feet in front of the real Christmas tree (not decorated yet).
Player
๐ฆ๐ฎ๐น๐ถ๐ฝ๐ผ๐๐ฒ๐ป๐
@Salipotens
Something I found in Creality Cloud today.
Printed with Hyper PLA on K1 Max with the 0,1 mm profile from cloud slicer.
Player
๐๐ฑ๐บ๐ฒ๐ถ๐ฒ๐ฟ
@sdmeier
I designed and printed a Gift Card Holder.
Printed on CR-6 SE
Sliced in Cura
Nozzle .4
Layer height .16
Bed temp 60
Nozzle temp 210
Player
๐ฆ๐ธ๐๐น๐น๐
@Skully
So I designed a replacement ornament dome that had broken somehow in our ornament box. This ornament isnโt just ordinary. This is a gift that I gave to my wife so it was very precious. Iโm WALL-E and sheโs Eve. Iโm the person who very reliable and old school and shes a super corporate primp lady so it has a lot of meaning. Well, the glass dome cracked and she was very sad. So I jumped into action designing a silver dome to go with the theme of our Christmas tree. I carefully pried and peeled away the broken glass around the hanger and figures and luckily did not cut myself or get glass in my finger. I designed the dome in TinkerCad. The second step was trying to figure out how to make a hollow sphere because Tinkercad isnโt that fancy. So I measured the glass thickness, dome size, and how far the opening was. I took two spheres, one the size of the actual globe and the other one a measurement thickness smaller than how thick the glass was than the original dome size, and cut into it. youtube it and it will make sense how the program works. I then took a can shape, flattened it, and made the opening. I then added some stars to allow the light to come in as I was not able to print it in clear and I knew the wife would love it in silver. I also didnโt smooth out the sphere on purpose because it goes with the trend of machines. Next, it was printing time. Knowing I wanted a perfect globe I did not use tree supports. All I used was brim and made about 9 brims to support this unit. I was amazed at how just that little bit supported the print since it did not have much surface contact. I printed the unit In Geetech Silk PLA on the Creality Silk PLA profile while reducing the speed because I wanted to produce fewer vibrations to prevent knocking it off its print, Increased the temp by 5C because it helps the silks be shinner, and BAM perfect print! This was printed on a Creality K1.
Player
๐จ๐บ๐๐ท๐
@Umuju
Printed on Ender 3 pro with Monoprice Pla+ white
Bed 60
Hotend 215
Speed 60
15% cubic infill
Painted with akrylic paints with clear spray coat
โ
Player
๐
๐ฎ๐๐ถ๐ฒ๐ฟ๐ญ๐ฎ๐ฑ๐ฐ
@xavier1254
Hello, I just (for the moment) printed in resin on my Creality Halot One this little Santa Claus
Player
๐๐ถ๐ฟ๐ฒ๐ป๐๐ฝ๐ฎ๐ฟ
@zirenspar
Angel Pikachu fanart christmas tree decor/ornament/bauble I modeled and sculpted in blender then 3d printed on my creality ender 3 pro and painted. The wings is made of glow-in-the-dark filament
No supports
very easy to assemble: the wings are fitted to the slots the at back of pikachu.
My Cura Settings
โข 0.16 on Pikachu while 0.20 on wings
โข speed is 60mm/s
โข use brim to ensure the pikachu model sticks to bed
โข infill: 10% lightning mode on pikachu while 20% lines for the wings
โข check lift head for layers less than 10 seconds for adequate coolingfile is available on my creality cloud profile: zirenspar
