I’ve been attempting to use color mapping with the Pika scanner by following the instructions in the wiki but it’s pretty vague. I Scanned in IR mode as one source directed. After completing the IR scan Scan the color mapping in, blue set at 25 resolution, point cloud, fast scanning, color mapping off because you can only do that in global marker and I’ve tried that process also and so I scanned the top and the bottom of the object then I fuse it, then aligned it, and meshed it. After mes the item it’s supposed to go into color mapping if you did step one properly and as far as I know I’ve done step one properly it’s I don’t know how to uh get it to go in the color. Somebody can help out that 'd be fantastic.
