Could I replace the head on the k1 max with the k1C head?
are the k1 max and the k1c heads diffrent? like could I swap the k1 max head with the k1c head? because the k1c head has the quick swap nozzle
Hello @Ezra_Clintoc:wave: :+1:
Welcome to the Creality Forum..! Creality
If the reason you are wanting to change out the extruder is because of the hot end you might want to check out these hotend replacements. I haven’t used any of these so I can’t recommend.
Triangle Labs Hotend Relacement for K1 Max
The Micro Swiss is a good replacement but it is more expensive and you can only use their nozzles… :cry:
Micro Swiss Hotend for K1 series
