CR-10 SmartPro bed leveling problem
I keep leveling my CR-10 SmartPro bed The nozzle is just right on all four corners and the middle when I go to run a process the nozzle is no longer near the bed it has raised up and the print job is no good is there any advice anyone can give I am very frustrated at this point
After each time you have leveled a corner you need to push the home button to home the nozzle(means save the position).
so you have to do that five times and then the nozzleheight will be right.
