CR-10S4 with BLTouch: Outer walls do not bond together (behave like book pages), despite 100% infill
Hello everyone,
I recently got a CR-10 S4 back up and running, equipped with a BLTouch. I flashed the correct firmware and calibrated the nozzle height.
I designed a simple test part in SketchUp: a 30x30 mm rectangle, 3 mm thick, with four 4 mm holes, making sure the mesh was solid. I then sliced it using Creality Slicer (4.8) to generate the G-code.
The print went well overall, and dimensions are spot on. However, I am facing a specific issue with the outer borders: the outer vertical walls do not fuse or bond together, while the interior infill (set to 100%) is dense and solid. The perimeter walls separate easily, behaving like the pages of a book.
      {"src":"https://forum.creality.com/uploads/default/original/3X/0/4/04eabdaef14dc7f9d3df35cccd883b2c8f68f9c1.stl","poster":"https://forum.creality.com/uploads/default/original/3X/0/c/0c97907ad03f56eea7294e9b1888d1d1f6c3c0ca.jpeg"}
Here are my print settings:
  • Filament: PLA, 1.75 mm
  • Bed temperature: 50 °C
  • Nozzle temperature: 200 °C
  • Ambient temperature: 12 °C
Does anyone have an idea what could be causing this wall separation, and how to fix it? Thanks in advance for your help.
