Hello,
I purchased a new CR-M4 12 days ago, on day 1 everything was setup and the first test print began. it ran successfully for 60 minutes (the rabbit) and at the 90% mark the extruder jammed and stopped feeding filament. I dissambled the extruder but it was jammed tight and they sent me a new extruder. 11 days later it arrives in the mail (the print hasn’t been on since). I reassembled the extruder, tested manual feeding, everything looked good, but the x-axis was grinding. I adjusted the belt and adjusted the x-axis, the wheels have firm contact with the rail and if held the wheels will rotate with some tension if pushed, but it continues to grind. I have tried loosening it so the wheels are more free moving and tightening to just no movement, but the same grinding outcome results, there is no wobble in the extruder. I have checked that the x-axis motor connection is properly seated on the board and everything is firmly connected.
If I heat the hotend and feed 10mm the step motor will not engage, I cannot hear or see any movement. If I retreat 10mm I can hear it engage very briefly and it immediately stops and will not engage again unless I power cycle the printer (I see no movement at any point). If I manually feed filament, it comes out of the hotend at 0.4 with no issues.
Any help would be welcome, after 12 days and only 60 minutes of printing, I would really like to get some jobs under way.
