I have been using my new CR Touch for a week very nicely and all of a sudden it has blinking red.
I have check continuity on the multi color cable.
It will not auto home on the z axis.
Any solutions would be helpful.
thank you!
Same here, had mine for over six months
with no problems - now it randomly works or doesnt. Tried replacing the main lead from the printer to the head - I read they are prone to breaks. the mini cable to the probe is fine - I checked continuity on that. Pin is straight.
Same issue, it was working perfectly and suddenly it stoped working!
Make sure the pin that touches the build plate is all the way down.
Gently pull it down to make sure it’s not stuck.
It is not stack I can pull it down and it goes up, if I go to the settings and reset y stop flashing, and I can deploy it and stow it. But when I run self test y deploy and stow one and start blinking red again
did you resolve this? I’m having the same issue.
No. I got to disabled the cr touch in order to continue printing. But I still couldn’t make it work the sprite extruder well ![]()
