Cr - touch. Need help
Hey everyone,
I installed a Cr- touch( without filament sensor) my Ender 3 a couple days ago. At the time I was unaware but I downloaded the BL-Touch software. Since the install when I go to print it will get around 2 minutes into the print and just stops. Fans are still going, screen is frozen. This happens with several prints. I have the 4.2.2 motherboard. I have installed Marlin 1.1.2 onto the machine. I have since then found the correct CR-Touch firmware and installed it. I’m unsure if it took the firmware though. How can I check? Here is the file of the CR-Touch firmware I downloaded. Ender-3_HW4.2.2_SW2.0.8.27_CRTOUCH.bin.
Below are the troubleshooting steps I have taken.
Reinstalled firmware
Checked G-Code of print
Checked G-Code of Ultimaker Cura
Any suggestions would be amazing!
Guessing this isn’t on an Ender 3 V3 but a V2?
If you don’t mind me asking where did you find the firmware. I tried to use Ender-3 pro 4.2.2 mainboard firmware (32 bit) but it didn’t have the file (Ender-3_HW4.2.2_SW2.0.8.27_CRTOUCH.bin) you used.
Thank you for your time,
nexusguy59
Hello Everyone,
I figured this out if anyone wants a Step by Step I am writing an article to put on my site to instruct others who are first timers or noobs if you will.
Just contact me via here and I can send it to you also.
Thanks everyone,
nexusguy59 aka Michael
