CR touch not deploying
A few years ago, I was gifted a Creality Ender 3, I have since upgraded the main board to 4.2.7 and added a CR touch. Recently, I discovered I hadn’t been using the CR touch correctly.
When I try and deploy the CR touch, it doesn’t deploy. I did have another CR touch which wouldn’t let me turn the machine on. I have since discovered that the ground pin was touching the +5V pin on the CR touch end. When I tried to start the ender with that CR touch, it just wouldn’t turn, hence I am a little concerned that I have damaged the board somehow.
So the question is, have I fried my main board, I have a Creality 4.2.7 board.
When start the machine, instead of deploying as it should on start, it just lights up red, when I try and deploy manually, it’s just red.
I am wondering if I need to get a new board.
Any help is appreciated.
Did you check the fuse on the main board? 4.2.x boards have a fuse on them, just to the side of the incoming power wires. It’s a blue 15 amp micro-fuse, similar to what’s in cars today. You can pull it out and replace it.
The main board is working as expected. If the fuse had gone it wouldn’t even turn on.
I have tried anothe CR touch, another main board, but I still get the same issue.
These are some tests I conducted:
  • I reflashed the firmware
  • From, Reddit, I have measured the voltages on the CR touch end and from the main board (without the CR touch connected, these are the results:
  • |COLOUR|PIN|Voltages on the CR touch end (CR touch not connected|Voltages on the main board end without the CR touch connected|
COLOUR PIN Voltages on the CR touch end (CR touch not connected Voltages on the main board end without the CR touch connected
White GND 0V 0V
Black +5V 5.02V 5.02V
Yellow SIG 0.24V 0.24V
Red GND 0V 0V
Blue OUT 3.16V 3.16V
  • The firmware I have installed is Marlin 2.0.6, Jun 11 2021, Ender-3
  • Manually deploying the CR touch - flashes with a red light
  • Self testing - flashes a red light
  • Nothing happens when running:
    • M280 P0 S10
    • M280 P0 S90
  • When trying to run the Z-axis it works as expected
Did you resolve this issue?
