CR10-SE Nozzle Type
Just spent hours trying to determine what type of nozzle type was being used in the CR10-SE. I didn’t want to take it apart, but finally had to as there was no information anywhere and various form were just posting guesses! I can confirm, after careful measuring that it is the K1 type nozzle with an M6 thread which is 15.23mm long. Creality posts drawings describing it as 15mm
long but I measured with a depth caliber from the end to the shoulder.
It’s the same on the Ender V3 KE, CR10 SE, and K1 series.
PS: I am trying to get info from Creality on whether they are going to make a Unicorn version for the CR10 SE.
I just tried to replace the Hotend on my CR-10 SE with a Hotend from a K1 (because my local distributor only had the one for the K1 in stock). It’s mechanically mostly compatible. The only problem is, that the cavles on the K1 one are shorter. Swapping the temperature Sensor from the old one into the new one is easy enough. But swapping the heating element is a bit trickier. I think, only a soldering iron will help me here.
Just leaving this comment here to maybe save someone in the future some hassle.
