Creaking noise when moving the bed
Hello!, since almost the first week that I have the printer, I have a problem with the bed displacement. When it moves to the bottom, it makes a creaking sound several times. At first it sounded in a few movements, but now it sounds always and in more points (before only about halfway).
Do you know what it is and how to correct it?
I have greased the rails, but I have not noticed any change.
I include video so you can see what I mean.
I see it happens just when it’s reaching the end.
Check that you don’t have anything rubbing under the bed. I had to change the gauges and when I reassembled the bed, a cable was rubbing against the black plastic piece that holds the two rails.
If it’s not that, check that there is nothing obstructing the belt gears.
And if it’s none of those things, loosen the belt and check that it’s not the motor or the pulley on the opposite side.
